This may need the zappar guys @Seb @George @Bob
Hi this seems to be working for me now thanks. …well it goes through to giving me the code, i use my phone which scans and seems to accept the preview scancode, but my zap/zappar doesn’t then appear?
Hello Everyone,
I have the same issues.
I’m in trial version and I canno’t preview anything.
If you have any answer to this issue, it would be very helpful !
Thanks,
BR from France
Baptiste
If you are scanning an image tracked experience then once the zapcode is scanned, you will need to point your device at the target image.
@baptiste, please make sure you are logged into the correct ZapWorks account. You can log out at any time by clicking the lightning bolt in the top left-hand corner of Studio.
If you are still having issues then there might be something blocking Studio’s preview/publish process. I’d recommend temporarily disabling any anti-virus or firewalls and reloading Studio.
If the problem persists then feel free to email support@zappar.com, where we can look into the issue further.
Many thanks. I’ve got somewhere with it now where I can see my project and have it animated.
Hi everyone!
I’m currently having the same issue with the preview where it’s “preparing to upload” and “uploading package,” the progress bar completes, but then the window disappears and I never get my preview.
Any insight would be very appreciated!
Hi. I’ve just checked. I have the latest version of zap works desktop. Osx version. Previewed a project, it loaded the log in/authorise screen. Then uploaded package etc. The dialogue screen disappears as progress bar completes and I get nothing. No next step, no scan code. Like it’s just missed a step or not fully operational. Thank
Sarkari Result Pnr Status 192.168.l.l
Same problem here, we are running a workshop and stuck… A windows version is buggy, an OSX cannot preview with the progress bar bug.
I have had problems with it as well. Locks up when debug it open. I have to click back and forth between zappar window and debug to get the debug to go. Also after a update my webcam doesn’t work most of the time. I have to use a usb camera.
I was told there should be a update to zapworks soon and to keep an eye out for it.
Same issue here. Preview uploads, I scan the code and all I get is ‘unlocking’ in Zappar. Same thing when I try to publish. All up to date, logged in etc. Same issue across multiple PCs and Mac
A right royal PITA…
Hi @sportsdz25,
Sorry for the late reply -
This happens when the account you are logged into doesn’t have an active seat assigned to it. You can click preview/publish and the progress bar will appear but the zapcode will not. We are looking at ways to show an error message to hopefully make it a lot clearer.
@MrPropre sometimes the log-in and progress bar modal show up below the Studio window itself, could be the issue you are experiencing?
@TK422, I have replied to your support request directly, but for others that might be having the similar problems - the “Unable to connect” error can appear either when there is no stable internet connection, or if an experience has never been published to that specific project. I’d recommend double-checking that the project that relates to the trigger has an experience published to it.
That was our problem here, that’s good to have a message so the user know how to fix the problem.
Still no joy. There are no issues with my connection (I can publish other experiences just fine) and the problem persists across multiple computers and connections with this project. The experience is publishing up to the project - it appears in the project log and I can even DL the ZPP file and re-import into Studio, but I just can’t get this project to preview at all.
Hi again. I’ve rebuilt the project from a (much) earlier version that worked and all seems to be well. There was definitely something amiss with the ZPP file!
Hi @TK422,
I had taken a look into your ZPP and there are errors in the experience. Errors are shown as red squiggly lines:
Although Studio will allow you to preview/publish, when scanning the trigger (zapcode) the experience may not run as these errors are stopping it.
Please try fixing the errors and try launching the experience again.
Thanks George!
I started again and it’s working like a charm now
Cheers!
Hi all,
I have a similar preview error. When I click preview I get the upload screen then the “preparing to preview” screen and then I receive an error message with a compile error. (see attached). I have tried logging out then logging back in and restarting zappar and the problem persists. I have also made sure I have a stable internet connection.
Can anyone help me troubleshoot this? Thanks in advance!
Got it, thank you George!
