Rotate multiple planes around a point
Hi guys
Great development tool. Just getting to grips with it.
Building a 3d photo selection tool. The objective is to have the photos rotate round a centre point say vector 0 0 2.
The way I am trying to set this up is to use a group node set at 0 0 2 and have this relative to the tracking image The photos being placed at equal angles around 0 0 2 and then set to be relative to the group node.
Rotating the group node via scriptrotates the child nodes.
Is this logic sound in Studio?
The difficulty I am having is the placement of the planes which although using calculated co ordinates for their positions they are always out of position when previewed.
I may of course be having a brain fart…
Have I missed something simple?
Thank you
Cheers Pete
Should work. Is your group a child of the TrackingImage?
All working was a positional issue in the end
Now trying to rotate with a button press. However xxxxx.rotation([0,0,50]); sets a position and does not seem to be incremental.
Am experimenting with
parent.on(“pointerenter”, (e) => {
// Runs when pointerenter occurs on the parent node
// https://docs.zap.works/studio/scripting/reference/object/events/pointerenter/
Z.every(100,Move);
function Move () {
const xxxx = symbol.nodes.xxxx;
Get rotation of xxxx
Increment rotation by fixed amount
Set new rotation of xxxx
Is there a better way though?
Cheers
That’s the way. You can also check this thread:
All sorted jvouillon
Will post my scripts and methods for other later
Cheers
Pete
