Programmatically set up timeline
It would be great to be able to set up or change a timeline programmatically.
For example,
timeline.addProperty(node.position);//add node’s position transform to timeline
timeline.KeyFrame(node.position, [0, 0, 0], 0);//add or change keyframe that sets node’s position to [0, 0, 0] at time 0
The main advantage of this is using variables to set up timelines instead of hardcoded values. Basically being able to adapt a timeline to specific conditions. In fact, extend this to controllers and states. I don’t see why you can programmatically set up nodes but not controllers, states, and timelines.
EDIT
I guess I love timelines, this is my third timeline suggestion :joy:
Timelines with multiple start/end values
Hi @marks,
Thanks for the feature suggestion.
Our timeline functionality was designed to be user-friendly and allow for visual feedback of the user’s timeline setup, so I don’t believe we’ll be adding this feature for the foreseeable future, as it would make it less accessible to our users.
However, I’ll mention this to the team and see what their thoughts are on it :slight_smile:
Thanks again,
Hm, I think I didn’t explain it well. I don’t want any of the existing functionality to stop working, everything can continue to work as it is. But by adding this feature it would allow more power to the users. So who wants to keep using timelines as it is they can, but the feature would unlock more flexibility for those who want it. You can set up the nodes in the hierarchy visually by dragging the assets, but you can also do it with pure coding. So just more possibilities doesn’t take away the user friendliness. I fail to see that :thinking:
