Hi folks. I’ve built the map. But the launch button is greyed out and cannot be selected. Have I missed a step?
Thanks in advance
Samsung s7
Thanks in advance
Samsung s7
No suggestions? Have I put this in the wrong forum? Missed a huge sign somewhere that says it doesn’t work with a galaxy s7? Broken an unwritten rule of the forum? Give us a clue
No rules broken, I just missed your earlier post, sorry for that.
There were some UI bugs around lens calibration and the state of the launch button - if you toggle the lens setting back to “on” and then click calibrate lens you can then select to use it without a lens which should get the launch button enabled again (assuming you’ve also successfully paired a controller and built a map).
The UI state bugs will be fixed in the next release.
Hope that helps.
That worked. Much obliged sir. Undoubtedly more stupid questions to follow when I get a chance to play. Thanks again
Steve g
No worries, that was definitely a bug on our side that it wasn’t properly enabled in that case.
