Hi All,
Anyone know how to create a custom mask from a png rather than using the default circle or square mask?
Stephen.
Hi All,
Stephen.
Hi Stephen,
The masks are actually 3D models. You would need to take your PNG and create a mesh from it in a 3D software package, export it as an FBX or POD and then import it into Studio.
Hope this helps
Ok thanks Mark, I’ll give that a go.
Cheers
Stephen
Mark,
Can you explain more on how to make your own mask?
I’m looking to make a book with a window (open mask part) to show whats under it.
I have a 3d fbx file but it doesn’t work like a mask. If I make it clear i can see thru to my Target image past the things in front of it. Unlike the normal mask.
Hey Steve,
Can I just confirm you’re following these steps in Studio:
I have checked and everything looks good.
here is a screenshot I have 2 books one with the color set 0 the other to 1.
Hi Steve,
Mark’s currently away, but I can help you out.
Just as with your other project, could you send through these files to support@zappar.com too please?
I’ll have a look through them for you.
