2D Picture Flying Effect
I would like to make an image have the appearance that it is “flying” towards the user by making it fly on the z-plane. Is changing the z-axis coordinates the best way to do this? I tried doing that, but it doesn’t appear to be doing what I want it to be doing. It should appear bigger as it goes towards the user and flies out, but it isn’t. Any help would be great, thanks!
Hi There,
You need to make sure your image/plane is ‘relativeTo’ a 3D space for changes in the Z-axis to have any visible effect.
The simplest example of a 3D space is the Z.camera space.
The gif below shows nothing happening when the z position is changed until the relativeTo value is switched to Z.camera
Cheers,
