Hi, I’m trying to train images for tracking with the zapworks cli but I get this error when I execute “zapworks”. Am I doing something wrong?. I used “npm i -g @zappar/zapworks-cli” to install the command line.
Hi @max.ojeda,
I’ve got a couple of questions which will help us track down the issue:
I see you’re using Windows. Which windows are you running on (10?) 32 or 64 bit?
Does it throw the same error if you try training an image zapworks train path_to_image.jpg
Thanks for getting back with the windows version
Which versions of node/npm do you have installed?
You can check this by running npm -v
and node -v
in cmd
This are my node and npm version
Maybe npm is pointing to the wrong directory? I would suggest confirming that node modules are indeed being installed to the path seen in the error you’re getting.
npm config get prefix
Might reveal some more info
was this resolved. I’m having the exact same issue
