I used zapworks init to create a starter project. This worked great. But then I added the GLTFLoader to load a model. This doesn’t work in the ZapWorks template. I get the following error:
Uncaught SyntaxError: Cannot use import statement outside a module - GLTFLoader.js: 1
zappar-threejs.js:1 Zappar for ThreeJS v0.3.33
zappar-threejs.js:1 Zappar JS v0.3.15
zappar-threejs.js:1 Zappar CV v0.3.14
index.js:46 Uncaught ReferenceError: GLTFLoader is not defined
at index.js:46
I’m guessing the problem is because the ZapWorks project doesn’t use module syntax.
