Do you know if it is possible to write a script that is activated when the user taps twice rapidly on a button or hotspot, similar to a double-click with a mouse on a computer?
Thank you
Thank you
Here’s the way I’d do it (for better or worse - I’ve barely tested this and I’m not known for good code):
const my_button = symbol.nodes.my_button_node_thingy;
var first_tap_seen = false; // this'll keep track of whether we've just seen a tap
function callback_func() {
if (first_tap_seen) {
text_flag.text("single_tap"); // or call your single tap stuff here
my_button.on("pointerdown", (e) => {
if (!first_tap_seen) {
// no tap has been recently, so note that a tap
// *has* been seen, but we'd better wait and see
// if another tap happens. Our callback function,
// will be called after a brief delay to check.
// one of two things can happen. Either the
// delay passes without the user tapping again,
// in which case the callback function can say
// it was a single tap.
// Or the user may tap again before that delay runs out
// in which case we can say: hey, that must have
// been a double-tap.
first_tap_seen = true;
Z.after(250, callback_func); // 250ms - set it shorter
// if you like
} else {
// a tap has already happened recently, so this must be
// a double-tap
text_flag.text("double-tapped"); // or call your double-tap stuff here
// note that the "single tap" callback function will
// still be called, but it won't do anything
// as we've set that first_tap_seen flag to false.
