This is a suggestion. I can create a reference to a node’s position, for example. And then on the parent node I can set the position. Ok. However, suppose I create a controller in the referenced symbol where I change the position. Now, the position that I set in the parent node won’t be considered, just the value inside the symbol with the referenced position. I think it would be great if the controller inside the symbol used the referenced value instead. Since I made a reference, it makes sense that the controller would look at the referenced value, not the value set in its own symbol.
