Suppose I have an image called “x”. I have 2 subsymbols called “z” and “w”. The parent of both subsymbols is “k”. There are 2 situations:
- I import “x” in “z” and “w” separately.
- I import “x” only in “k”, and reference it in “z” and “w”.
My question is this: Is there any difference between both situations in terms of memory usage? I always assumed that it’s best to follow situation 2 because situation 1 would double memory usage. But I’m wondering if my assumption is true. Does zapworks detect this internally and optimize to use just one reference to the image?
The reason I’m asking this is because it’s annoying to use situation 2, because if you go inside the subsymbol, you can’t see the image that is referenced in the parent. So it becomes hard to maintain when you want to make changes.
If Zapworks does not optimize situation 1, it would be nice to have access to global media files, so I can use these media files inside the subsymbol without referencing from the parent, so I can always see the image inside the subsymbol. That is not the only advantage, it’s about encapsulation and separation of concerns, so the subsymbol wouldn’t need to depend on the parent because of this.
I’d argue that it would be great if Zapworks could just optimize situation 1. Zapworks does know where all assets are referenced as you can check going to Analyze>Final download size…If Zapworks can just do this there wouldn’t be a need to implement global media file access.
