Hi!
I wonder if it would be possible to combine photospheres and tracking image like having a photosphere rising up when tracking an image.
Best regards
Eva
Hi!
Best regards
Eva
Yes you can. You have to make a timeline that starts from the photosphere that is relative to target and ends with the photosphere relative to the attitude orient. Probably you can play also with the position but I’m not sure… A photosphere far away from the 0 position or relative to target is seen as a sphere texturized with the 360 picture that you use. Ciao!
Great. thanks Marco, I will try to realise that!
