Unity is published as webgl, and this error will appear when I publish new content, which can only be solved by clearing the cache
Hello @791127866
Welcome to the forum.
It’s possible that this error is due to some missing function/API which is being called repeatedly (probably from Unity’s Update). This might help you to identify the missing function call. Otherwise, you can try disabling Strip Engine Code
or setting Managed Stripping Level
to minimal from Editor player settings to be sure Unity is not removing any method that you may use at runtime.
Do share more details like console logs or project link here, so we can test this on our end to better help you.
Best
