I’m wondering if it’s possible to alternate between two different textures on a single 3D object in the timeline. If so, how would I go about that?
Ryan
Ryan
Do you need to fire it from a timeline?
Will the timeline be in with the 3d models subsymbol?
Because your going to need the texture to be in the 3d models subsymbol and if your playing a timeline you can try Timeline Labels found HERE
I would look at this as well
ZapWorks Studio: Changing an Object’s Texture Using a Button
My project involves hieroglyphics (2D) on a tablet (3D) , they will change from black to glowing red.
I’d like the texture to be changing automatically, on startup, on a loop.
Is this possible?
That’s exactly it. I’m trying to breakdown this project, could you give me some insight into how you did this?
Thanks Steve!!
