Trying my first project using the Panorama 360 tutorial. (https://docs.zap.works/studio/tutorials/interactive-360-panorama/). I’m following the instructions but when I do the steps in #8 (Set Photo Sphere Material), the park 360 image doesn’t preview (like it does in the tutorial). I get nothing. Just the blank, black screen. What am I doing wrong?
Hi @kidfreshieaf,
It’s difficult to tell what could be going wrong without having a look at the project itself.
Could you please send a screenshot of your project, showing where you’re currently getting stuck? It might also be worth double checking any value inputs up until that point in the tutorial.
I am having a similar issue. I am a Zappar Studio novice, and have followed the ‘Interactive 360 Panorama’ tutorial and completed successfully. Now, I am trying to edit and use my own panorama photo vs the one provided in the tutorial. When I change the Photo Sphere Material to my new panorama, in the previewer it shows a black and white checkered pattern vs my new panorama image. What am I doing wrong?
Here is the image I am trying to use, which is a panorama (not a full 360).
It looks like you have 2 materials listed. There shouldn’t be a “—”
Try adding a new photosphere and set it to the new photo. Then change this one to no visible
I’ve taken a look and I believe the issue is because your image is too large. Its resolution is 6144 x 2816. Studio only supports images below 2048 in either dimension (Width/Height).
Please try reducing the image resolution and try importing the new image.
Let me know if that fixes the problem.
