Hi All, I am learning to use zappar. I am trying to recreate an AR experience I made in Apple’s reality composer into zappar. If this is not the correct section of the forum please feel free to move it.
In short it’s a visual story that works by starting with most elements as “hidden” then for example a text elements is tapped so it disappears and another one is shown, audio plays and so on
you can see a short example here CELCIS AR Card 2 - YouTube
Could someone confirm that in the browser editor there is no way to set elements as hidden (and show them later via a trigger)? I had a look to the help knowledge and it seems this mechanism could be achieved scripting by using “hide(), show(), display()”. I have yet to delve properly into the coding and scripting in the desktop editor and before I invest much time in it I wanted to check this is indeed doable.
Thank you very much
