Hi ZapWorks,
Here is a bit of context.
I’ve been trying to develop an image tracking AR application that will display a 3D holographic model. To make it look better, I’m trying to add the Fresnel effect to the shader material, here is the reference to the said effect and implementation. https://codepen.io/Fyrestar/pen/WNjXqXv.
However, it doesn’t seem to work well somehow with the @zappar/zappar-react-three-fiber. Here are some screenshots I took.
Vannila Threejs Canvas + default camera:
If I use the vannila canvas with the default camera settings,<Canvas> <Suspense fallback={null}> <Scene></Scene> //The model </Suspense> </Canvas>
It looks as expected.
ZapparCanvas + default camera:
If I use ZapparCanvas component without ZapparCamera<ZapparCanvas> <Suspense fallback={null}> <Scene></Scene>//The model </Suspense> </ZapparCanvas>
It somehow already looks different (Screenshot under reply).
ZapparCanvas + ZapparCamera
If I use both ZapparCanvas and ZapparCamera<ZapparCanvas> <Suspense fallback={null}> <ZapparCamera userCameraMirrorMode="poses" rearCameraMirrorMode="none" /> <Scene></Scene>//The model </Suspense> </ZapparCanvas>
Only the colour (blue) I set for the Fresnel effect remains, the diffuse colour (black) is completely gone. The material seems just broken. (Screenshot under reply)
I’m not an expert in shader, but I suspect it is because the way ZapparCamera works is different from the default Threejs PerspectiveCamera? Please help, thank you very much!
