Apologies in advance if this is a dumb question, but I’m noticing that 3D models (.fbx) that are a couple KBs after export increase to a few MBs in the final download size in Studio. Why is this?
Thanks.
Thanks.
Cause your project have other elements, not your 3D model only… I guess.
I don’t have any textures so I cant image what else would be taking up space…I also have a model that reduced in size in Zappar
Hi @ashlee.fms,
All model formats (other than glTF) are converted to .pod files when imported into Studio. You’ll see this when you import it and subsequently a modal appears saying “Converting Model”. If you right-click on the model in the Media Library and export it you’ll see this. Size increase may happen here, but it depends on the different file formats.
I hope this clears it up.
