Hi @shot,
A ready
event will fire when the given node is loaded. Most nodes can be dragged directly into a script to create a ready event. You can also right-click on the root node to create a root ready event handler, which will run once the experience is launched.
You will get an event handler like this -
parent.on("ready", () => {
// Runs when ready occurs on the parent node
//Activate prompt to user here.
Much like ready events, target images also fire seen
and not seen
events respectively. Right-clicking or dragging the target image into a script will allow for seen
and not seen
event handlers to be created.
symbol.nodes.Target_Image.on("seen", () => {
// Runs when seen occurs on the Target Image.jpg.zpt node
//Activate tracked content
symbol.nodes.Target_Image.on("notseen", () => {
// Runs when notseen occurs on the Target Image node
//Activate user prompt
Here’s an example project that might help - Seen and not seen example.zpp (300.3 KB)
You can find lots more information about this here, as well how the above can be set up using Actions.
