How can I use click event on a-frame?
I try to use a-frame examples, but it does not work correctly.
The sample only responds when the target you tap is in the center of the screen.
I want the user to be able to tap wherever the button is.
This has been resolved.
Thank you.
I’m facing a similar issue, and can’t get the click event to work properly. Would you mind sharing your solution?
