Hey Guys,
I wanted to create an experience where a jet flies over and it leaves behind a smoke trail.
I can’t use a video as the jet is moving in a curve.
So,i am using particle effect instead.
The problem with particle effect though is that it is attached to a parent and it can not leave a trail behind.
I tried changing the parent but there doesn’t seem to be an option for that inside a subsymbol from where the smoke is coming.
Any possible solution would be much appreciated.
Ayushya
