Hi @ryan2160 ,
I believe that I have answered your question via email, however this might be helpful for other members of the community!
When you import 3D Models into ZapWorks Studio, occasionally you will have to input them manually. There is a materials section on the importing documentation here, and there’s usually a little hint in Studio to let you know when textures are missing in this case:
Adding the texture file should reflect changes:
If you are having trouble seeing this dialog, you may have to import them manually. You can do this by double clicking your 3D Model in the ‘SYMBOL DEFINITIONS’ panel, and then finding your model’s material in the hierarchy. Click on it, then find the ‘Skin’ property. There may be more or less materials, depending on each lighting material.
Hopefully this is helpful!
Have a great day,
Francesca
