Are you able to add 3D objects into the designer (.fbx files)?
Studio is designed for this purpose, alongside advanced customisation features for your zapcode and AR content.
Designer is meant to be used for it’s easy drag and drop functionality to create 2D based AR content (such as videos and images) on a tracking image.
You can check out our article here for which tool you should use, and here for the Studio docs to help you get up and running
Hope the information helps you.
Best,
Hi Zappers.
Alternatively, in the designer, i have used isometric images to create a 3D effect, with good results.
Best,
WEBeCia
