If you’ve already placed the group of object way off in the distance (relative to the PhotoSphere) then when you parent it to the Anchor instead, it’ll still be way off in the distance somewhere (though possibly behind you now, depending on which way you’re looking). I’m guessing the group’s Position is quite a way from [0,0,0] (?) My bad - I should have thought it through better.
You need two reference points, origins, in the scene, ideally. One locally - that Anchor - that you can use to pull the group up close to you so you can animate it. Then another off in the distance, set relativeTo the PhotoSphere, that you can attach your group to once you’re finished playing with it and want to “put it back” in the scene.
I’d create a new group to use as that far reference point - add a new Group, set it relativeTo the PhotoSphere, and copy the Position coordinates from your “3D objects” group to it. You should now have an empty Group in the distance, where the objects are supposed to be when you’re done.
You can now go to your “objects” group, set its position to [0,0,0], and then set its relativeTo to either your Anchor, or that distant Group we just set up. You can switch between them freely, and your group of objects will jump to the near or far points respectively. (If you want to move where that far point is, you can do that easily too - move that empty “far” group. The objects will be carried along, but their local position will still be at [0,0,0] as far as they’re concerned)
The problem was that your group of objects was positioned a long way away from whatever it was parented to. Which was grand for the PhotoSphere - but meant that when we wanted to pull it closer to work on, that great big offset was still there.
