Offloading some post-it notes. Some are niggles, some are Quality of Life things:
- Could you have Studio save the panel layout, either globally, or per-project? Every time I open it I have to resize the panels the way I like 'em, and it never remembers
- Could you correct the button text on the Export >> “Would you like to commit before exporting?” dialog - it should be Yes / No, not OK / Cancel
- After renaming an item in the media library, please exclude the item’s original name when checking the name’s not already in use. If you leave the name unchanged (say, for instance, you accidentally double-clicked an item and then click away to cancel the rename) it pops up a dialog saying “Name in use!”… which is silly, because it’s in use only by itself. Note this doesn’t happen in the Hierarchy, just in the Media Library
- A time-saver for us: could you re-use Preview and Publish dialogs, rather than instanciating a new one each time? For some reason I seem to regularly end up with a stack of Preview dialogs after doing lots of quick edits / iterations. Sometimes you don’t want to immediately close the dialog before editing, as you may want to scan the Zap code again to check something. Once you hit Preview again, there’s no need for that previous dialog - if you could either close or re-use it that’d save us a click
- Could you add up the download sizes for us in the Zap_menu > Analyse dialogs please? Seems like that’d be something a computer ought to be doing for us (!). Totals, please
Mentioned in a couple of other posts, notably by @marks:
- Being able to select multiple objects and drag them around [whether that’s moving nodes in the hierarchy, or moving visible objects on the canvas]
- Being able to do ctrl+c ctrl+v to duplicate objects
- Being able to change multiple objects’ properties at once by selecting them and changing the property [for example, you may have a bunch of nodes that need their relativeTo setting]
These are almost more important than my list: being able to select multiple nodes simultaneously is so important for workflow, and the missing Cut/Copy/Paste functionality is very frustrating.
