Hello everyone,
I’m using Zappar with PlayCanvas in a project, but when i’m trying to use lookAt with zappar, i get weird results
I created a sample project to test this stuffs, without Zappar the lookAt works as should be, the object look at where it needs, but when i set inside the zappar template, the object looks where should be, and rotate together with the camera movement…
Here are two links, one with the same problem in the PlayCanvas forum, and other with the project sample with the test that I did.
https://playcanvas.com/project/879716/overview/zappar_moviment
