I have an animated 3d asset in my scene that I want to hide behind a mask. The normal full 3d plane option doesn’t seem to be working???
any suggestions?
Dan
any suggestions?
Dan
Hello Dan,
An object with layerMode set to ‘full_3d’ will appear over objects earlier in the hierarchy except those with full_3d layering that are positioned closer to the camera.
Consequently, since the mask’s layerMode is set to ‘full_3d’, you need to make sure that:
I hope this will help.
Margaux
Hi Margaux,
not sure if you got me email, but the 3d asset doesn’t seem to have a layerMode for me to set as full 3d? As I realisethis would be the normal thing to do, but hence my confusion when I couldn’t find this option?
thanks again
Dan
[EDIT]
Had the same layermode problem so i revived the post but now i managed to solved it!
Davide
Hi @ayushya
Just double click on the 3d model symbol in the Symbol Definitions Panel and you have full access over your model property including layerMode.
Now in your main scene just turn the opacity to 0 and you got your mask.
Hope this help
