Using Zappar on a wall
We’ve got a large vinyl on a wall and I wanted to get a Zappar code placed next to it so people could scan it and see a large video or image etc on the wall.
I’ve just done a trial of it and once I’ve scanned the code, the content comes up quite small. In order for the content to be a similar size to the vinyl on the wall, would I need to make the code larger? Or is there a step I’m missing?
It sounds like you’re not using a tracking image to track your content to the wall.
I’d recommend you check out our Best practices article on tracking images and test uploading an image of your wall as a tracking image and see if that helps you.
In addition, if you’re using Studio, be sure to check out Getting Started guide here for help on image tracking.
