Hello. I’ve seen it done in some of the uses of zapworks but can’t find any documentation on how to do it. What is the process for setting up the tracking image that doesn’t actually have a zap code on it?
If your using studio it’s the same as with one. Just don’t have it in your image. You will always needed to scan a code to start.
You don’t need a tracking image if you are using only a 360 photosphear.
