hello, im having a problem, i create a web faceAR with unity3d and upload using zappar hosting, it run smooth without error, but when i want to switch to selfhosting(https domain, already registered) i got an error like image i attach
is there something i miss?
im follow the guide and i dont really understand this 2 point
- Files in the Zappar library ending with the
.wasm
file extension should be served with theapplication/wasm
mime-type - Several files in this library (and likely others in your project too) compress well using
Content-Encoding: gzip
. In particular you should serve files with the following extensions with gzip content-encoding:.wasm
,.js
,.zbin
,.zpt
(when build unity webGL im already select gzip)
thanks for the help
