Hey Seb,
Bump for interest.
Any update on this?
Thanks
Jason
Hey Seb,
Bump for interest.
Any update on this?
Thanks
Jason
Actually yeah I did see this. I didn’t see the tutorial for it. Awesome! Thanks Steve!
Oh thats your project Steve?! Dang that looks like quite a lot of work, very impressive. Ok so how do you get multiple targets tracked? lol
Hi Jason,
One way, is to add the target images to subsymbols. Load the 1st sub symbol and check if it is seen or not. If not, unload the current symbol, load the next one, and so forth. When the subsymbol is found continue to check its seen status in order to restart the search loop as soon as it is not seen again.
Cheers,
Hi guys,
Just thought I’d mention a few things regarding multiple-image tracking in Studio.
While creating an experience that tracks from several targets is possible (as is evident from some experiences we’ve seen, including @stevesanerd’s competition entry), it is not currently supported nor recommended due to the instability and unreliability of the implementation in its current state.
Support for multi-image tracking has been discussed internally, but as it’s part of a much larger discussion we don’t have any further information to share at this point, unfortunately.
For those of you eager for this type of functionality, we’ve created a brief example to show how our internal team simulates tracking the same experience from multiple targets, using Deep Links.
We’ll be looking at creating more comprehensive documentation/examples around the use of Deep Links in the future.
The ZPP’s and target images can be downloaded here - Simple Deep Link.zpp (2.1 MB)
Simple Deep Link 2.zpp (2.3 MB)
To understand this I would suggest printing out both the target images.
To summarise - these targets are linked to similar experiences showing a 3D model and a screen relative button. When scanning the zapcode on the first target, the 3D model will be tracked to target image 1 (try looking at target 2 and the 3D model will not track).
Touching the button will 'launchUrl(…)` of a deep link and load the second experience. The 3D model will now be tracked to the second tracking image! Touching the button again will then re-load the first experience and re-track the model back to the original target, and so on.
Thats great Jvouillon! Ill experiment with what you mentioned. Do you happen to have a sample of the code for this? I’m much more of a visual learner and i don’t really have a background in code.
I understand the seen and not seen scripts for sure, but the loop checks are where i may get held up.
Thanks!
Jason
I’ll try to make a simple example…
Meanwhile… the idea is,
in the subsymbol:
In the main root,
Hope it can help,
Hey jvouillon
I think ive got the subsymbol code, which works.
const Plane = symbol.nodes.Plane;
var tracker = function() {
Plane.visible(true).enabled(true)
parent.on(“seen”, () => {
tracker();
However, the root code and the loop check is where I’m a bit lost. Any help would be greatly appreciated.
Thanks!
The code of the trackingImage in the subsymbol, should be something like:
var trackingImageStatus = false;
parent.on("notseen", () => { trackingImageStatus = false; });
parent.on("seen", () => { trackingImageStatus = true; });
export function getStatus(){ return(trackingImageStatus); }
Then, from the main hierarchy, you can call the function this way:
var imageSeen = symbol.nodes.your_symbol.nodes.code.getStatus();
Thanks so much for all your help so far. I’m still a bit lost but have everything communicating properly. This might be a bit advanced for me at this point. Might need to do some JS tutorials to better understand a lot of this.
All a learning curve, Jason - sure you’ll get there with it. Know everyone here will help out however we can :).
Thanks a lot James, really appreciate it. Seems like a nice community.
So im still working on it. Im stuck at the root stage of this.
function myRepeatingFunction() {
var imageSeen1 = symbol.nodes.Track1.nodes.Script.getStatus();
var imageSeen2 = symbol.nodes.Track2.nodes.Script.getStatus();
Z.every(2000, myRepeatingFunction);
Any more help would be great.
Thanks all.
Jason
1 - First, the sub symbols are not added to the hierarchy, but loaded dynamically.
var trackingImageDisplayed = Z.Symbol(« symbol_1_name »);
symbol.nodes.trackingImagesGroup.push(trackingImageDisplayed);
2 - Then call your repeating function to check if the loaded symbol is seen or not:
var trackingImageFound = trackingImageDisplayed.nodes.code.getStatus();
if (trackingImageFound ) { ... }
3 - If not, then you unload the current symbol, by clearing its parent group:
symbol.nodes.trackingImages.clear();
4 - Now, you can load the next one… ( goto 1 )
The whole process is not complicated, but for sure it’s easier is you are comfortable in JS.
May be you should try first to dynamically load then unload a symbol.
Jean.
Just posted my code for my Multi Tracking Image.
Enjoy!!
Hey Steve this is great! Thank you! The page seems to not be loading correctly though. Having trouble downloading.
Sorry fixed link.
http://rentanerdcomputers.com/wp-content/uploads/ZapWorks/Multi%20Tracking%20Image.zpp
Thank you Steve for sharing!
I was wondering if there’s any news about this implementation? Seems kind of crucial to a lot of experiences.
This thread has been super-helpful already, many thanks to everyone contributing!
