Issue: When the user (usually accidentally) sets a node’s RelativeTo property to itself, the viewport turns black. Undoing the action or changing the RelativeTo property does not resolve the issue.
Affecting: Any open Zapworks Studio windows.
Workaround: Update the RelativeTo property to something other than the node itself, then close out of any open windows of ZWS.
I want to note that this isn’t like, a major issue, but having one accidental click completely freeze your preview is quite disruptive to workflow, as I sometimes have multiple ZWS projects open at once to use for reference, and with the UI getting reset each time you open a project, it means any time I accidentally misclick, I have to spend a decent chunk of time getting re-set-up in my project.
