Hi there! I’m new to Zapworks Studio (and zapworks in general) but I’m working on a project that is essentially a giant iSpy mural. Think of something that’s like this image:
My issue is that I want to have multiple lists for the SAME image. I managed to get the code to open each subsymbol when the correct button is tapped (I have 3 subsymbols made) but the image tracking only appears to work on the first subsymbol. Is this due to limitations of ZWS? Or could there be a bit fo code I’m missing? I’m trying to avoid having to put it all into one large subsymbol and then hide each set via states because I feel like that will make the file very complicated very quickly. The project I’m currently working on is just a small section of a larger mural.
I’m not afraid of scripting as I have a wee bit of coding knowledge and can wrap my head around it pretty quickly, so if the only solution is more scripting, I’m open to learn.
(Note: I wanted to add that I’m familiar with the “Multiple Tracking Images” thread and have used that in a different test, but I believe this is still slightly different than what I’m trying to achieve.)
https://forum.zap.works/t/support-for-multiple-targets/318/35
EDIT: I guess while I’m still at it, I can’t seem to get the “Look for Graphic” subsymbol to work. I have it as a child of each subsymbol that contains a tracking image, have placed the “seen/notseen” code according to the import notes, but I can’t seem to get it to show.
