I have recently completed a project using Alpha Video in Studio.
The first few attempts failed to upload the video. The original video was 103mb.
When I reduced the video size to less than 50mb it worked.
Is there a size limit on mp4 alpha video that can be embedded into a studio project?
Hello @chris2 ,
I don’t know if is there any size limit but I know that the videos embedded on Zapworks Studio has to respect some parameters that you can find trought this link:
https://docs.zap.works/studio/audio-and-video/filetype-support/
And here for a quick read:
P.S: I still suggest that you visit the link to read the full article.
Hope you gotcha!
att, Higão.
Thank you @higor!
There isn’t a size limit on MP4 Alpha video. Would you be able to send us the video before compression so we can take a look at the issue?
We also recommend you read this article on how to optimise your Zappar experience once you’ve finished developing your experience on Studio.
Thanks Bob,
Yes I had problems uploading the video to the server, Next time I will download the error log and upload the error log to the support forum.
I did succeed the following day using a shorter clip from the video…
Below is the Zap code…
Hi Chris, are you crazy? I use very often alpha videos on Zapworks studio, but as you know the suggested weight of all the experience is about 5 mb! I suggest to use the streaming video player symbol, here is the tutorial: https://docs.zap.works/studio/audio-and-video/alpha-video/
Thank Eni,
Yes I did see this tutorial when making the experience.
This is my next venture.
I am a beginner so Have a lot to learn…
