Does anyone have a solution to fake shadows on a transparent material in Unity? I have found tutorials for WebAR, but not sure if they’ll work for Zappar.
Drausio
Drausio
Found the solution:
Create this shader and apply it to a material on a plane:
Shader “Custom/TransparentShadowCollector”
Properties
_ShadowIntensity (“Shadow Intensity”, Range (0, 1)) = 0.6
SubShader
Tags {"Queue"="AlphaTest" }
Pass
Tags {"LightMode" = "ForwardBase" }
Cull Back
Blend SrcAlpha OneMinusSrcAlpha
CGPROGRAM
#pragma vertex vert
#pragma fragment frag
#pragma multi_compile_fwdbase
#include "UnityCG.cginc"
#include "AutoLight.cginc"
uniform float _ShadowIntensity;
struct v2f
float4 pos : SV_POSITION;
LIGHTING_COORDS(0,1)
v2f vert(appdata_base v)
v2f o;
o.pos = mul (UNITY_MATRIX_MVP, v.vertex);
TRANSFER_VERTEX_TO_FRAGMENT(o);
return o;
fixed4 frag(v2f i) : COLOR
float attenuation = LIGHT_ATTENUATION(i);
return fixed4(0,0,0,(1-attenuation)*_ShadowIntensity);
ENDCG
Fallback "VertexLit"
