Scale from pinned point
I want to transform an image in my project from the bottom left corner by a state-change. Standard the image is scaled (for example) from the middle of the image. Is it possible to ‘pin’ an object, so it gets scaled from that pin-point?
Illustrator calls it a referencepoint.
BTW: I’m trying to upload an image, but always get an error: undefined method `etag=’ for #
Greetings,
Ferdy
You can try it by adding your image to a group which is located at the reference point you want. So when you scale the group the image will be scaled from that point.
Cheers,
