According to the documentation it should be possible to run an application on a local network running on a 10.* IP address. This is unfortunately not working for us. Using port forwarding with the Chrome DevTools and going to 127.0.0.1 works but we need to test on iOS also so this is a blocking point. When I check on the Distribution Hub the entries for AR Self-hosting 192.168.* is there, but 10.* is not. Is there a way to add this?
I use the Chrome Web Server to serve and NGRok to host. Try that.
jrDev
