Issue: The color of a node is one of the properties that is affected by its parent’s color. This behavior does not happen when you use the relativeTo property instead of placing the node directly under the parent. See relativeToColorIssue_cleaned.zpp (1.8 KB).
Affecting: Zapworks Studio
Workaround: If the node is supposed to have just one parent, place it directly under the parent node instead of using the relativeTo property. If the node can have multiple parents, use relativeTo but ignore the parent’s color and set the color of the child directly.
