Hi everyone,
Here is my situation… I have an existing experience, a mural on a wall that has AR that is run from a QR code and playing in the browser.
I am doing a temporary update to the experience and want to make it a portal… a few questions.
I’m wanting to run the portal off the target image so the doorway will appear in front of the wall in a spot I want it and not how WorldSpace Portals work by picking your own placement anywhere. I have limited space to work with.
Will a portal work running off a QR Code in the browser?
Will a portal work off an image target? I mean, once it activates will the experience die if you lose the tracking target?
Is there a way to use WorldTracking and have the door appear where I need it to?
Thanks for any help you can give me.
Cheers
