Hello. I wanted to make one project from an image tracking and then a selfie. Is it possible all in one project? If Yes. Then how? And even better without codes, I’m not friends with them.
Yes you can.
Use the Image tracking as your main load. Then have a button that will open the photo op you want.
You should be able to do this with little to no codes.
Thank you very much! I had such an idea, but I didn’t believe myself…
