Multiple Triggers on a Poster (Image Tracking)
I created a poster to act as my tracking image. When I created it I put three triggers on it, each trigger is exactly the same and only links to the one project. Will the image tracking be confused by having multiple triggers (that are the same)?
If you have triggers on your real tracking image you should make your tracking image for your project the same. Ex( your real world image should be the same as the one you set in your project)
Past the first scan it shouldn’t care if there is more than one.
I don’t understand why you would if they all go to the project. Are you thinking one for zappar app and one for WebAR?
