how can i use the same button and ever time i tap on it something else happens .
example :
tap 1 changes color .
second tap on the button changes color again to different color and soo on
There is more than one example posted on the forms here. I know I have posted one or two. I’m on my phone so I cant post one for you now.
can you tell me what to look for. did not find anything
No problem. Here is a link to post with some code you use.
(How to add multiple "pointerdown" scripts to one object)
You will need to change the lines
symbol.controllers.toggle.elements.invisible.activate();
and
symbol.controllers.toggle.elements.visible.activate();
to be what you need.
thank you
it works
6 diffrent angles of the item in one key tap.
code :
var angle = 0;
switch (angle)
case 0:
symbol.controllers.turn_house.elements.n45_degturn0.activate();
angle = 1;
break;
case 1:
symbol.controllers.turn_house.elements.n90_degturn.activate();
angle = 2;
break;
case 2: symbol.controllers.turn_house.elements.n135_degturn2.activate();
angle = 3;
break;
case 3:
symbol.controllers.turn_house.elements.n180_degturn3.activate();
angle = 4;
break;
case 4:
symbol.controllers.turn_house.elements.n225_degturn.activate();
angle = 5;
break;
case 5:
symbol.controllers.turn_house.elements.n315_degturn.activate();
angle = 6;
break;
case 6:
symbol.controllers.turn_house.elements.n0_degturn.activate();
angle = 0;
break;
Nice!!
Let me know if you need anythings else.
