I am trying to test the Face Tracking 3D Model sample github project on iOS by building it on Windows with iOS Project Builder. However, I am getting the following error when building the XCode project with iOS Project Builder,
Libraries/com.zappar.uar/Plugins/iOS/zappar-unity.mm(18,27): error: invalid token at start of a preprocessor expression
#if !ZAPPAR_METAL_SUPPORT && (TARGET_OS_IOS || TARGET_OS_IPHONE)
Libraries/com.zappar.uar/Plugins/iOS/zappar-unity.mm(93,27): error: invalid token at start of a preprocessor expression
Libraries/com.zappar.uar/Plugins/iOS/zappar-unity.mm(104,26): error: expected value in expression
Libraries/com.zappar.uar/Plugins/iOS/zappar-unity.mm(163,25): error: expected value in expression
#if ZAPPAR_METAL_SUPPORT
Libraries/com.zappar.uar/Plugins/iOS/zappar-unity.mm(175,24): error: use of undeclared identifier ‘s_mVertexBuffers’
void* mapped = s_mVertexBuffers[fmb.first]; //malloc(bufferSize);
5 errors generated.
- [arm64] Linking UnityFramework…
ld: file not found: build/Release-iphoneos/UnityFramework/arm64/Libraries/com.zappar.uar/Plugins/iOS/zappar-unity.mm.obj
Can someone let me know what could be going wrong? I have the ZCV.bundle folder at the root of my iOS build.
The image tracking sample project worked fine using the iOS project builder and I was able to test out the sample on my iPhone by building it on Windows.
