I’m doing a work with zappar webar through zapworks studio. my image target was printed approximately 10 centimeters wide and 6 centimeters high. is a relatively small target. when I’m with the smartphone next to the target, the application works perfectly. But when I move away from the target, the application gets unstable, shaky, and sometimes loses recognition. below is the image target used.
what practices can I adopt so that it is possible to use the application in a stable way, at a certain distance, without changing the size of the target?
