I have read your article about multiple objects on a bezier curve (Multi / model start position on a bezier circle) but it didn’t help me with my problem so far.
I am working on a postcard that ´will have the function of a tracking image. If the AR experience starts I want several images float around this postcard, similar to the experience shared here: https://www.xamarinarkit.com/lesson/3d-photo-gallery-surround/.
I though´t about placing the images on a circle shaped bezier curve or to build a grid…
How do I set the end position of the images on the bezier curve in regular distance to each other? If I set the distance all images are above each other on the same spot…
A function like “LookAt” to make the images face the tracking image (better: the transparent sphere on top of the tracking image) does not exist. Is there a way to center the images?
I guess it is possible to set other bezier curves (one for each image) to make them fly from the tracking image to their final position?
Eva
