I uploaded a 3D model (format .glb) to the ZapWorks Designer tool, but when a I select the file to load in my project, I receive “Failure loading component”. The 3D model has 6.7M size. Do you have a hint how to solve it? Thanks. Karam Takieddine
Any luck on a resolution?
Did the model have any textures used?
If so, double-check the textures file type and resolution. 6.7 mb is a little on the larger side for an asset, you might be able to save some size by optimizing textures.
Hope that helps.
