In the Ancient History Competition - Ancient Egypt Tutorial there is a FactText node with a property that contains text, which is displayed when you tap a button. Could you pass on the FactText subsymbol. It is not included in the associated resources zip file I downloaded from the tutorial.
I think there was a completed zpp file as well. If so you can load it up and then export the sub symbo you need from it.
Ok, thank you!
Ok, thank you!
