Please see attached example. There are 3 white planes. On pointerdown they become transparent, on pointerleave they become visible again. You can’t make the 3 planes become transparent at the same time. The third plane you click on won’t be registered. This limitation also applies if you try to detect three pointers on the same plane using pointersmove
test.zpp (3.8 KB)
