- Build your own prototypes using the Templates in ZapWorks Designer
- Customise by replacing with your own assets
- Apply Design Thinking
- Consider your assumptions
- Create Test & Learn Framework
- Play with different scales/ settings
- Explore 3D Space/ Walk around it
- Explore 2D/3D UI
- Document insights in Test & Learn Framework
- Consider what you’ve learnt from taking a user centric approach / initial idea → where you ended up
- Post your project and key insights on the ZapWorks Forum*
Thank you @emma.moore for posting the Webinar project details here.
I look forward to see what everyone was able to build in ZapWorks Designer and what they’ve learnt using the Design Thinking Framework:)
