Hi, I used the unity with Universal AR to build AR project. and I have a problem to change the message on permission screen.
the message is “Almost there …” “in order to…”
I can confirm the plugin zcv.jslib is reading from
https://libs.zappar.com/zappar-cv/2.0.0/zappar-cv.js
and it contains the messages. so Should I download the js file and changed it ? What is the best way to do this?
in the documents, it says
If you'd rather show your own permissions UI, you can turn off the standard Zappar permissions by un-checking the
Permission UI (WebGL) parameter in the **Zappar Universal AR** Project Settings.
I’m not sure how do I show my UI. is it possible to get more details on instruction?
Thank you.
